Re: 1086 air conditioner
Posted by Shawn on June 04, 2003 at 15:07:38 from (205.188.209.140):
In Reply to: 1086 air conditioner posted by Steve Oliver on June 04, 2003 at 03:19:23:
First of all the system would not be overpressured wihtout compressor running. R134 gas, uncompressed will have a pressure that relates closely to ambient temperature, Example 80deg F system pressure will in the 80lb + range. Your system will not overpressure until the 300lb range, & if correctly retrofitted would have pop off valve that expels pressures above 400 lbs"roughly". I think your sytem has a bad pressure sensor on the high side, or a short in wiring of same. i could tell you how to bypas these sensors, but I wont due to possible healthrisk to you & your compressor. To correctly work on the system it must be connected to a gauge set, then you could determine if system pressures are ok. Without knowing the actual pressure in system & hot wiring you could either over pressure & vent refrigerant or burn up a compressor that doesnt have enough refrigerant. In other words let someone take a look at it with the equipment necessary, just guessing on the repair will only cost alot more money if you make a mistake. My 2 cents
Post A Followup
: Re: Re: 1086 air conditioner
