Hydraulic help - basic questions
Posted by Doug Stockman on June 05, 2003 at 02:53:41 from (65.229.131.34):
Greetings: I have a 1959 460U with a two point fast hitch and an aftermarket front loader. The person who owned the tractor before me did some interesting things with the hydraulics. I want to make the hydraulics more useful. The tractor has one standard hydraulic valve. That valve is fed by the hydraulic pump. That valve is always kept open by a wire holding the handle down. That valve is set for single acting. The output from that single valve then feeds a two spool aftermarket valve like can be bought from Tractor Supply. The two spool valve feeds the front loader and is set for single action (power up, gravity down). The return from the two spool valve empties into the return from the standard IH valve. The front loader works as expected. The main problem is with the 2-3 pt. Hitch. The former owner has hydraulic lines coming from the top of the IH standard valve. The draft control lever is used to raise and lower the 2-3 pt. Hitch. Of course this is very slow and I do not get the full range of the cylinder. I want the 2-3 pt. Hitch to work as expected. Ideally, it will be double acting – power up and down. I do not know enough about hydraulics, but I see a few options. Please comment on these options and how to proceed. 1.Can I Tee the supply hose coming from the pump into the IH valve? I would then use the IH valve to control the 2-3 pt. Hitch. The other output from the pump Tee would go to the two spool aftermarket valve. Would I be able to then return the two spool outflow into a Tee that then empties into the IH standard valve? I think the former owner said the IH valve did not work correctly. If that is true, I would have to rebuild the IH valve before I could use the 2-3 pt. Hitch – not ideal for this season. 2.Can I connect a single spool ConvertaValve from Tractor Supply to the two spool valve that presently controls the loader? This to me seems the easiest solution if possible. I just add the single spool then move the two 2-3 pt. hoses from the draft control to the single spool. I then have real hydraulics for the 2-3 pt. Hitch. I of course have to move the outflow hose from the two spool to the end of the valve chain (i.e the end of the 1 spool which is connected downstream to the 2 spool). 3.How do I make all this double acting? Is there a way to tell if the 2-3 pt. Hitch hydraulic cylinder is capable of double acting? I think the loader cylinders are capable of double acting. They have closed off ports that are presently not used. Pheew! I hope that made sense to someone. Right now the tractor is beat and just for work. Therefore, originality is not an issue. Fast and functional is the goal. Any help would be greatly appreciated. I have a couple days off so I hope to play with the tractor soon. Thanks in advance. Doug Stockman Penfield, NY
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
