Re: Some Regular Questions
Posted by Ludwig on June 05, 2003 at 06:36:40 from (68.160.160.173):
In Reply to: Some Regular Questions posted by Bill Smith on June 04, 2003 at 20:43:01:
It was very common to swap the F20 manifold and carb onto a Regular. In fact I still have the F20 manifold from my Regular. The Regular carbs are VERY primitive the F20 a bit less so.
In this case I would hazzard a guess that you've seen an F20 with either replaced steering gears or a replaced front bolster. As you've said that'd make more sense than moving the trans and engine.
I also wonder if you could remove the steering gear cover on an F20, say if you'd broken the steering gear, and have it look like a regular?
I can't tell the difference between an F20 and a Regular by gas tank and oil filter, can you enlighten me or was that just a guess?
Post A Followup
: Re: Re: Some Regular Questions
