Re: Re: 1941 Farmall A overheating
Posted by groatboy on June 10, 2003 at 12:05:52 from (198.97.56.71):
In Reply to: Re: 1941 Farmall A overheating posted by Greg Miller on June 10, 2003 at 10:38:20:
The radiator shop let the radiator sit in an acid
bath to clean out any build up. Then they put it
through a pressure test and found no leaks .
While the radiator was off I ran water through
the inlet to the block and it flowed at the same
rate through the outlet. So as far as I can tell
from doing that, the block is clean. I believe
this is the original radiator but not sure since
both my dad and grandfather have passed on
and would be the only ones to know. By the
way, the oil and filter was changed before the
radiator was reinstalled.
Thanks for your insight on the problem.
Hopefully it will get figured out soon.
Post A Followup
: Re: Re: Re: 1941 Farmall A overheating
