Re: Need advice on Farmall 200 steering problem
Posted by Haas on June 12, 2003 at 05:55:41 from (12.65.25.116):
In Reply to: Need advice on Farmall 200 steering problem posted by bradford253 on June 11, 2003 at 18:30:51:
The 200 is I think the same a C or Super C regards the steering gear. If you have had out the worm gear and the worm wheel (steering gear) and inspected the bearings, can't see what else would be wrong. If you replaced the big seal on bottom of the main steering shaft, you would have to have had the bearings out. However as you describe the problem, it sounds like one or both of the bearings that support the main steering shaft are bad. Also sounds like you have a wide front. Steering gear is the same as narrow front which I have. Don't know what effect the wide front would have.
Post A Followup
: Re: Re: Need advice on Farmall 200 steering problem
