Re: cover over rear engine bearing cage on F-30
Posted by here, try this on June 12, 2003 at 19:14:18 from (65.165.16.68):
In Reply to: cover over rear engine bearing cage on F-30 posted by okla/kans Bill on June 12, 2003 at 16:42:40:
been a while since i had one in my hand bill. many of those old engines used a grove that tended to throw oil back toward bearing by centrifical force. dose this make sense? I bet the paper was a gasket. You can make a nice new one out of some heavy paper. As far as you post about geting the old bearing out, your not trying to save it are you?
Post A Followup
: Re: Re: cover over rear engine bearing cage on F-30
