Re: Bearing cage removel on F-30
Posted by dlp on June 12, 2003 at 19:19:08 from (130.184.114.35):
In Reply to: Bearing cage removel on F-30 posted by okla/kans Bill on June 12, 2003 at 11:56:56:
I pulled the bearing cage with the crank when I removed it. I guess you figured out the crank comes out the back & the other end of the crank has to be dissasembled also. I guess you could pull on the cage, but I would be concerned about busting it. The I.D. of the bearing must really be stuck to the crank.
Post A Followup
: Re: Re: Bearing cage removel on F-30
