1940 Famall A oil pressure problem
Posted by Jim Creecy on June 15, 2003 at 11:11:05 from (66.175.158.11):
When I first start my A the oil pressure reads approximately 60 lbs of pressure then after about
15 minutes the the pressure drops to about 30 lbs
at full throttle. What could cause this drop in pressure? I am using Pennsoil 10w-30. I would appreciate any input and suggestions to identify what could cause this to occur.
Thanks,
Jim
Post A Followup
: Re: 1940 Famall A oil pressure problem
