Re: 1940 Famall A oil pressure problem
Posted by NDS on June 15, 2003 at 16:07:24 from (64.12.97.13):
In Reply to: 1940 Famall A oil pressure problem posted by Jim Creecy on June 15, 2003 at 11:11:05:
Wish I had your problem my 1941 A has not had 30 psi hot oil pressure since I bought it in 1962 and it is running srong after many hours of work. To awnser your question back plate on oil pump is probaly warped. You can either replace or lap down old plate. 30 psi hot is not bad for an A though if it stays out of red at idle I would not be concerned about it. Just my 2 centc others may have different opinion.
Post A Followup
: Re: Re: 1940 Famall A oil pressure problem
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
