Re: Re: model 12 mower
Posted by Hugh MacKay on June 16, 2003 at 13:49:24 from (64.228.11.9):
In Reply to: Re: model 12 mower posted by ET on June 16, 2003 at 07:24:59:
ET: A good Farmall mower man mows the headlands right to a point, never stops or lifts the mower on a corner. You don't waste time traveling the headland with cutter up. If you don't mow across the headland, you don't rake the headland and you don't bale on the headland. Those 7' IH mowers were all good for 2 to 3 acres per hour and when they were built a day was 12 to 16 hours.
Post A Followup
: Re: Re: Re: model 12 mower
