Re: Re: Re: model 12 mower
Posted by ET on June 17, 2003 at 06:55:31 from (134.179.136.130):
In Reply to: Re: Re: model 12 mower posted by Hugh MacKay on June 16, 2003 at 13:49:24:
Hugh,
Keeping the cutterbar in the grass and cutting is not a problem on flat ground with square corners but the real world I live in has hills and triangle shaped fields, not to mention the knolls and diversion ditches. I have never found a way to keep the cutter bar in the hay on those 120 degree plus corners in the triangle pieces.
Post A Followup
: Re: Re: Re: Re: model 12 mower
