Re: Super A engine continues to fire after shutti
Posted by phil on June 17, 2003 at 09:11:59 from (12.47.224.12):
In Reply to: Super A engine continues to fire after shutting o posted by Jon on June 16, 2003 at 19:27:31:
Another thing to try that has worked for me is to run a cold sparkplug. The recommended sparkplug for your tractor was optimum 50 some years ago. Thing have changed, gasoline, engine compression, etc. Probably what is happening inside your engine is that the electrodes are "glowing", so when the engine is shut off, the electrodes are still hot enough to ignite the gasoline. A colder plug will eliminate this. You might want to try a set of sparkplug adapters with automotive platinum plugs. I have and they work great!
Post A Followup
: Re: Re: Super A engine continues to fire after shutti
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
