Re: A brakes
Posted by BillWV on June 17, 2003 at 20:26:54 from (129.71.139.187):
In Reply to: A brakes posted by Scott in SC on June 17, 2003 at 19:45:09:
Yes, you have to pull off the final drives. The differential shaft is splined on the inside end and comes out with the final drive assembly. It's not a hard job, but the whole assembly is a little heavy and can be hard on the seals, especially on the right side, because the shaft is so long. I used a come-along to suspend the right side drive when reassembling.
Everybody I talked to recommended changing the seals while I had it apart, which I did.
Bill
Post A Followup
: Re: Re: A brakes
