Re: Re: Re: Re: farmall a start switch/rod help...
Posted by JONATHAN MIRGON on June 18, 2003 at 08:04:24 from (66.119.33.170):
In Reply to: Re: Re: Re: farmall a start switch/rod help..... posted by Merlin on June 18, 2003 at 06:03:35:
My 1940 (a) has the push type rod, I thought that it should be pulled instead of pushed, so i turned the switch around, after turning the the switch around the contacts on the switch and the starter would not line up , thus not engaging the starter. I made an extended rod for mine that connects beside the throttle lever, It seems to be a bit more convienent that way.
Post A Followup
: Re: Re: Re: Re: Re: farmall a start switch/rod help...
