Re: Re: farmall M 12 volt \power steering
Posted by farmall nut on June 18, 2003 at 21:00:41 from (65.240.57.98):
In Reply to: Re: farmall M 12 volt \power steering posted by Dave (CT) on June 18, 2003 at 20:36:45:
Dave, Someone posted a wiring schematic for H/M last month or so. Look in the archives on this forum. You didn't say what type power steering it has, if it is an aftermarket CharLynn, it will have a fluid resivor under the left front of the hood. Hood must be removed to fill it. I use Hy-Tran in mine and it works fine. I would think that any type of hydrulic/gear oil would be ok. Phillips makes one called HG Fluid that also works for the application. Have fun with your project.
Post A Followup
: Re: Re: Re: farmall M 12 volt \power steering
