Re: power loss/battery not charging
Posted by Phil Auten (TX) on June 19, 2003 at 04:52:25 from (208.189.120.213):
In Reply to: power loss/battery not charging posted by Jack on June 19, 2003 at 04:11:29:
Jack,
I would start with the battery. If the old battery was working for years and you simply replaced it, it sounds like the battery you installed has a problem. I would pull the battery and take it to a shop or dealer for a load test. It sounds like it has at least 1 shorted cell.
Phil
Post A Followup
: Re: Re: power loss/battery not charging
