Farmall Tractors Discussion Board |
Re: Re: Generator running hot on a Super A
Posted by lc on September 20, 1999 at 19:18:54 from (208.128.241.81):
In Reply to: Re: Generator running hot on a Super A posted by ltf in nc on September 20, 1999 at 18:21:28:
One other note. On the Super A I think there is a switch to set the charge to high or low. If you run it on high too much it will burn up the generator. It happened to us. THe switch should be set on low charge except for short time to charge up the battery.
Post a Followup
