Re: H needs a little help......
Posted by F20II on June 21, 2003 at 09:16:17 from (208.187.14.111):
In Reply to: H needs a little help...... posted by Bob on June 21, 2003 at 06:23:57:
Make sure that all connections are clean, like the other fellow said 6v systems are postive grounds, make sure that the cables going from the starter to the switch are ok. Clean all the cable ends real good, pull of the ground cable clean that end. The answer to the other question is if the battery is low you will show charge, if the lights are on the battery meter will show charge an if you have a short it will also so charge. Remember you have on most farmall H's four postion switch which is Low, high charge, light low and high, make sure that these connections inside the box on the back of the switch are clean as well. Hope this helps only my 3 cents :o)
Post A Followup
: Re: Re: H needs a little help......
