Re: Will IH wide front from M fit H?
Posted by Red Rider on June 21, 2003 at 20:47:33 from (66.248.104.48):
In Reply to: Will IH wide front from M fit H? posted by 26RED on June 20, 2003 at 11:45:25:
It depends on what wide front your M has under it. If it has the IH wide front with the tie rods behind the axle, then yes it will fit all except the stay rod ball socket bracket that bolts to the frame behind the axle. If it is the IH wide front that has the tie rods out front then plate that bolts under the bolster will be to wide for the H.
Post A Followup
: Re: Re: Will IH wide front from M fit H?
