Re: super m meets 12 volts
Posted by Doug in OR on June 21, 2003 at 21:27:47 from (12.225.51.197):
In Reply to: super m meets 12 volts posted by scotc on June 21, 2003 at 16:49:03:
Tell us more. Did you swap the generator and regulator from the truck too? If you didn't, there's no way you would be getting 20 amps while using that 6 volt regulator on a 12 volt battery. Measure resistance across the coil. If it shows about 3 ohms, you don't need the resistor. If it shows about 1.5 ohms, you need that resistor in line.
Post A Followup
: Re: Re: super m meets 12 volts
