Re: super m meets 12 volts
Posted by Dan on June 22, 2003 at 10:17:38 from (12.160.160.80):
In Reply to: super m meets 12 volts posted by scotc on June 21, 2003 at 16:49:03:
Did you change to negative ground with the new setup? You may actually be showing a 20 amp drain. When I converted my SMTA over to 12 volts with an alternator I used the inline resister between switch and coil. It is a chrysler type. Mine lasted about 3 years and then I had to replace it. It is really cheap so don't mind. I would agree that you shouldn't get any charge with the original generator and regulator. Have heard people say a 6 volt generator will put out more voltage if you have a different regulator but haven't tried that
Post A Followup
: Re: Re: super m meets 12 volts
