Re: Anti-freeze in oil on an M
Posted by Bill Smith on June 23, 2003 at 10:04:22 from (63.147.130.84):
In Reply to: Anti-freeze in oil on an M posted by Jeff in Wisconson on June 22, 2003 at 06:13:45:
I have an M with simular problem. I have it tore down right now. My problem appears to be a blown head gasket. The amount of antifreeze in my case was much less. Could ussually drain off 2 or 3 tablespoons of oil out of the pan after a rather lengthy time. I guess the amount could be alot different depending on where the gasket was leaking and so forth. I had the head off of the old thing after a couple of evenings work. You won't know for sure without a tear down though.
Post A Followup
: Re: Re: Anti-freeze in oil on an M
