Re: Re: Thermosyphon cooling questions
Posted by Al on June 23, 2003 at 17:24:50 from (65.160.63.48):
In Reply to: Re: Thermosyphon cooling questions posted by Tom Olson on June 23, 2003 at 05:52:15:
I have never heard about the difference in head gaskets. Will have to remember that difference.
I had my SA rebuilt in 2001. My mechanic was worried about the "gurgling" when shut off and put a waterpump on. He also said my new heat indicator didn't work. I am in the process of doing the cosmetic work now and will probably take the water pump off because it interferes with the radiator shutter linkage. Long story short, I took the "bad" gauge and put the sender in a pot of water on the stove and began to heat it up. Worked fine. I guess this means my Super A has the head gasket for the 113 engine!
Al
Post A Followup
: Re: Re: Re: Thermosyphon cooling questions
