Re: Re: 1946 Farmall B misses after 20 minutes
Posted by Steve - IN on June 23, 2003 at 18:48:32 from (12.223.205.149):
In Reply to: Re: 1946 Farmall B misses after 20 minutes posted by Question for Farmall Dan on June 23, 2003 at 11:01:14:
Mark, Remove, hood, plugs, and valve cover. Turn engine to TDC or top dead center on #1 cylinder - farthest forward cylinder. At TDC the pulley on the crank should line up with a pointer. If you don't have a mark/pointer, turn the engine with your finger in the spark plug hole until compression starts to blow your finger off the hole. You're close -- now take a drinking straw or equivalent and place into hole and turn engine and watch it ride up. When it starts to go down, you've gone too far, back up and go for the highest point. When that is done, the two rockers for #1 cylinder should be loose against the valve tops. Slide a feeler gauge in to measure the clearance. Don't have an A spec handy, but an H is .017" hot. Guesstimate .019 or .020 cold. If there's not enough or too much clearance, undo the lock nut on the top of the rocker and turn the screw with a screw driver until the feeler gauges begins to get snug. Do the other 3 cylinders the same way.... Also check the condensor and the coil, problems with them can produce similar results.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
