Re: Re: 1946 Farmall B misses after 20 minutes
Posted by farmalldan on June 24, 2003 at 09:53:23 from (64.154.26.248):
In Reply to: Re: 1946 Farmall B misses after 20 minutes posted by Question for Farmall Dan on June 23, 2003 at 11:01:14:
Steve pretty well covered it. Set lash with engine hot. I seem to recall that specs for the c113 is 0.014, but you need to confirm that. Memory isn't what it once was. No pointer on crank pulley on A, B, or C. Timing marks are on flywheel. Look through handhole at bottom of flywheel. Pointer is on front cover of bellhousing. Marks are very hard to find and I recommend Steve's procedure for valve lash. Setting ignition timing makes finding the marks mandatory.
Post A Followup
: Re: Re: Re: 1946 Farmall B misses after 20 minutes
