Re: Convert 300 to 12volt system ??
Posted by Doug in OR on June 24, 2003 at 11:20:43 from (159.121.94.198):
In Reply to: Convert 300 to 12volt system ?? posted by Dave K. on June 23, 2003 at 21:36:14:
A common mistake many people do is that they substitute 12 volt battery cables for the existing 6 volt cables. Six volt cables are heavier and have less voltage drop at the higher currents. Check your cables first - ensure they are the nice heavy cables you would find in a 6 volt system. While doing this, clean all connections completely. If the ground cable is bolted to the frame, undo this bolt and clean everything. The tractor frame. The cable terminal. The bolt. Hidden corrosion is the usual culbrit.
One last thing to look at is the starter itself. You might have worn brushes or bad bearings.
Two other items: Yes, 8 volt batteries do exist. As you've found, locating a charger for them is more difficult. Finally, converting to 12 volts is no big deal. I would not do it simply to mask another problem, though.
Post A Followup
: Re: Re: Convert 300 to 12volt system ??
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
