Re: Shifting problems with 684
Posted by JB on June 24, 2003 at 17:53:23 from (24.157.110.221):
In Reply to: Shifting problems with 684 posted by Danny on June 24, 2003 at 08:49:34:
Hi, Does the 684 have TA? My brother has a 684 with TA and it does the same thing. Sometimes when it is hot if you push in the clutch, it will not go again. The only way to start again is to put the hi/lo/rev lever in neutral position and release the clutch for a few seconds and then engage the hi/lo/rev level. Last spring we replaced clutch, pressure plate, bearings and had the flywheel turned but did not help the above problem. Interesting discovery when we did clutch job was that the main bearing cap behind the flywheel was loose. This tractor also appeared to use a little engine oil especially if you were working in a hilly field. There were never any signs of blue smoke only an occasional drop of oil from the clutch inspection plate. Since tightening the main bearing cap no more oil consumption. Since this is the first time this tractor has been split, I guess someone at the factory forgot to torgue the bolts down. I questioned an IH mechanic about the not starting problem and he said it was probably the hydraulic pump that drives the TA and the PTO. It apparently is located in the inspection hole between the clutch and the transmission. It is an independent pump that runs off the PTO shaft, sumps from the transmission, supplies the TA clutch in HI and the PTO clutch and dumps into the hydraulic lines that go to the oil cooler. Apparently there is a pressure test that can be done by breaking into the hydraulic lines on the right side of the tractor under the battery box. The other thing the mechanic said was there was a splitter/check valve on the pressure side of the pump to hold pressure on the HI TA clutch so the tractor would not run away on a slope when it was shut off. Now my brother's will not hold on a slope in HI TA when shut off. LO TA is OK. But appearently LO TA is a mechanical clutch and does not rely on hydraulic pressure. I hope someone has the cause or solution. JB
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
