Re: Quits when hot
Posted by Steve - IN on June 24, 2003 at 22:04:15 from (12.223.205.149):
In Reply to: Quits when hot posted by FarmallBailey on June 24, 2003 at 21:36:19:
FarmallBailey, From what you've said - my first guess would be the coil. If it's running hot, you're probably supplying it too much voltage -- and so it supplies less and less spark until the engine dies. Try getting a 1.8 to 2.0 ohm ballast resistor rated at 35 to 50W and sticking it inline from the igntion switch to the coil. That should keep the coil running cooler and the tractor running longer. You say gray then white smoke. Those are two different indicators. Gray usually means too lean - make the mixture a bit richers by unscrewing the main jet on the carb a bit. White smoke, you're right, is water, or steam coming off and that could be a headgasket. First thing you might test is the voltage going to the coil. It's either 12 to 14 or 6 to 7.5 or so. If the two terminals on the primary side of the coil measure >3.0 ohm, it wants 12 volts. If the terminals meausure around 2 ohms, it wants 6 volts. Next do a compression test at cranking speeds to see if any of the cylinders is greatly different than the others - which might indicate a blown headgasket. Also check for water in the oil. My guess is that it's the coil, but best to be safe and check for the headgasket as well. Good luck with it!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
