Re: PTO Problems
Posted by Gary-Miss on June 25, 2003 at 18:20:55 from (152.163.253.102):
In Reply to: PTO Problems posted by Papcharlie on June 25, 2003 at 02:58:03:
As I recall fromworking on the cub Farmall. they do not have a spring loaded detent ball like most of the rest. They have a shift lever that is spring loaded and you push it down to engage or disengage it. If the slot is worn out or the slot ted plate has loosened on its one bolt (I think) and turned slightly, it won't be held in by the slotted plate. Golod ;luck.
Post A Followup
: Re: Re: PTO Problems
