Re: M dies after start
Posted by Steve - IN on June 28, 2003 at 16:43:13 from (12.223.205.149):
In Reply to: M dies after start posted by Tom on June 28, 2003 at 16:21:04:
Tom,
Yes, could be the float bowl, metering jet, main jet - or anywhere along the fuel line.
Could also be a condensor or just a bad connection in the primary wiring; if you check the other side of the tractor.
Fun stuff - chasing down gremlins - but think of it this way: the tractor has no fuel pump, only a simple single throat carb, only 4 cylinders and no electronics. Troubleshooting your car would be 10 times the headache.
Good luck with it.
Post A Followup
: Re: Re: M dies after start
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
