Re: M dies after start
Posted by Jim on June 28, 2003 at 18:14:56 from (205.188.209.140):
In Reply to: M dies after start posted by Tom on June 28, 2003 at 16:21:04:
Check to see if there is a fuel strainer inside carb fitting where gas line joins carb. I worked on a Super A once years ago and found a clogged fuel strainer to be the problem. If fuel is getting to engine , I would check for a bad coil next. The coil can start to fail as the engine warms.
Post A Followup
: Re: Re: M dies after start
