Re: Stearing wheel on a 450
Posted by Red Man on June 28, 2003 at 19:08:11 from (65.239.206.126):
In Reply to: Stearing wheel on a 450 posted by Earl in Pa on June 28, 2003 at 18:25:28:
The center cap will pry off with a screwdriver. Loosen the nut on the steering shaft under the cap with an air wrench and take off. Spray the splined shaft liberally with PB Blaster, then use the the 3 small holes around the shaft for a puller.
Post A Followup
: Re: Re: Stearing wheel on a 450
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
