Re: farmall 140 stalls on incline
Posted by Hugh MacKay on June 29, 2003 at 19:03:10 from (64.228.12.29):
In Reply to: farmall 140 stalls on incline posted by jim burdett on June 29, 2003 at 18:12:25:
Jim: My first reaction is gas, your float may not be stuck, but may not have right level. It may need some adjustment.
The other item I have seen is, worn distributor shaft giving end play in the shaft. I had a similar problem with a Super A; rough ground, hills, a jolt, etc. it would stop. Distributor shaft was quite loose and I sent to CaseIH dealer and had it rebuilt. I understand there is no bushing when new but this is how they rebuild them. Results the tighter shaft cured my problem.
How to tell which is problem: if it sputters its gas, if it just stops probablty fire.
Post A Followup
: Re: Re: farmall 140 stalls on incline
