Re: straight pipe burns valves??????
Posted by Bob Kerr on July 01, 2003 at 21:47:44 from (152.163.253.102):
In Reply to: straight pipe burns valves?????? posted by rustywallace2 on July 01, 2003 at 11:58:37:
Under some conditions like after very hard usage in very cold weather a striaght pipe can let cold air back in through the pipe to a valve that is part way open and warp it, but that is VERY rare. If you run an engine with a warped valve, it will burn out because the hot exhaust gas leaks past when it is at its hottest and the valve can't cool itself on the seat.If you have a warped valve you will know it by the way it runs, one cyl will be weak and it may pop funny when under load. As for a straight pipe used in summer, run it and forget it, but wear ear plugs! Just look at some of the old timers that are left who ran F-12/F14s F-20s/F30s, 10-20s, 15-36s. Those guys all have hearing aids now!
Post A Followup
: Re: Re: straight pipe burns valves??????
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
