Re: Rough running F-20 - - - need your wisdom !
Posted by Bob Kerr on July 02, 2003 at 20:38:22 from (152.163.253.102):
In Reply to: Rough running F-20 - - - need your wisdom ! posted by Pete on July 02, 2003 at 18:48:06:
You might go back and double check the valve settings. Check them when the engine is thoroghly warmed up. Sounds like a valve (or valves)are not closing all the way. I like to set them a little to the wide side on the settings but I still run mine hard. The rockers should tap a little bit none the less. I don't have the specs for an F-20 so maybe some one will post them.
Post A Followup
: Re: Re: Rough running F-20 - - - need your wisdom !
