Rough running F-20 - - - need your wisdom !
Posted by Pete on July 02, 2003 at 18:48:06 from (24.236.157.238):
I have a rough running F-20 that I can't solve. Engine starts fine and runs smoothly at full retard on the mag. As I start to advance the spark, it starts to miss and continues to miss at full advance. Timing is fine. There is no back firing. Have tried: New points & condenser, cleaning out the mag, new plugs & wires. Have removed all the wires and watched them spark while in full advance at a low speed. All are sparking regularly. Engine has good compression. Engine speed doesn't appear to change the issue. Engine was recently torn down to rebuild the head and put in new rings. Rough running engine due to the mag setting was the same before and after the rebuild. Your thoughts on this guys ?
Post A Followup
: Re: Rough running F-20 - - - need your wisdom !
