Re: Regulator for 12volt gen?
Posted by gene b on July 04, 2003 at 03:55:12 from (65.230.144.139):
In Reply to: Regulator for 12volt gen? posted by Andy on July 04, 2003 at 00:44:16:
You need the DELCO-REMY NUMBER OFF YOUR GEN. There is no way to change regulators from 6v to 12 you should be 6v pos ground on the gen if it is original. Dont know what you are trying to do with tractor restore or just want it to charge it makes a lot of difference to how you aproach the problem. Much better staying with original set-up is cheaper than all the changes. Use 1ga cables for the ground and to the starter sw for best results.
Post A Followup
: Re: Re: Regulator for 12volt gen?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
