Re: Re: Re: 282 rebuild problem
Posted by K.B. on July 04, 2003 at 22:00:00 from (209.163.30.87):
In Reply to: Re: Re: 282 rebuild problem posted by dennis savela on July 04, 2003 at 19:40:38:
How long have you run it total? Almost sounded like a fuel problem, but since you say it will not run without the glow plugs, it's starting to sound like you are low on compression. Actually, it sounds like a fuel and compression problem. Get yourself a manual from the nearest Case-IH dealership, double check the valve lash, Do a compression test, start it up and crack each injector line loose one at a time to bleed air out. If that dosen't get you going, then it's time to let an old IH mechanic who worked on a lot of 560 Diesels look at it. Possible that the fuel pump and injectors need to be tested. What does the exhaust smoke look like?
Post A Followup
: Re: Re: Re: Re: 282 rebuild problem
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
