Re: Water Leak on M
Posted by rustyfarmall on July 06, 2003 at 12:18:32 from (199.120.81.232):
In Reply to: Water Leak on M posted by Kevin in Texas on July 06, 2003 at 11:58:37:
If you are talking about the left side as you are sitting on the seat, then the cover you mentioned is the water header cover, not the lifter cover. Drain the radiator, and remove the cover, then you can see what you are dealing with, if indeed you have a broken off bolt, or stud, then the problem becomes a bit more sticky, but still not impossible to remedy, you might want to enlist the help of a friend who is adept at these things.
It is not uncommon for these old tractors to leak in this area, should not be expensive at all to repair.
Post A Followup
: Re: Re: Water Leak on M
