Re: farmall 560 diesel
Posted by Brent on July 07, 2003 at 18:56:39 from (216.248.74.155):
In Reply to: farmall 560 diesel posted by marv on July 07, 2003 at 15:25:03:
Don't know about diesel, but on my 560 gas the fill port for hydraulic fluid is on the deck on the right side of the shifter, it is about 3" semi-triangular shape. Unscrew the three bolts and lift the thin plate steel cover off (it is same shape as the shifter plate, uses same gasket too I think).
The hydro filter is on the right (as you sit on it) side down towards the bottom but on the vertical face of the transmission case, in front of and below the brake pedals. Take off the cover and there is a filter element inside.
Post A Followup
: Re: Re: farmall 560 diesel
