Re: Two-way hydraulics on H or M
Posted by Haas on July 08, 2003 at 05:36:12 from (12.65.19.238):
In Reply to: Two-way hydraulics on H or M posted by Black Creek Farm on July 08, 2003 at 04:04:26:
Run hose from one of the pressure outlets on the Lift All Unit to a two way valve. Run return from valve back to either the Lift All reservoir fill port, or to the reservoir drain. Then lock the Lift All lever in the lift position so oil flows through the valve. Be aware that max pressure generated by the Lift All is around 800 psi, so you may need a larger cylinder than normal to work your equipment.
Post A Followup
: Re: Re: Two-way hydraulics on H or M
