M Minimum Rear Wheel distance
Posted by Bill Perry on July 08, 2003 at 10:01:34 from (205.188.209.140):
What is the minimum out to out distance that you can get an M rear down to for hauling. I would assume you turn the center drive wheel with the dish to the inside and put the rim back on. Will the rim go on the inside of the driving wheel or the outside after turned? Tires are 12.4 on 38 inch x 11 inch rims. Is this a two man job or do you need some sort of hoist?
Post A Followup
: Re: M Minimum Rear Wheel distance
