Re: Farmall 404 problem
Posted by JB on July 08, 2003 at 19:24:31 from (24.157.110.221):
In Reply to: Farmall 404 problem posted by J in Pa on July 08, 2003 at 16:56:02:
Had the same problem with SC, but the pilot bearing was only a bronze bushing. It would fail about every 2 years. This tractor had a loader with hydraulic pump on PTO shaft and no live PTO so there was a lot of clutch action.
Interesting thing though is the pilot bearing only turns when the clutch is depressed.
In your case is the clutch depressed for long periods of time at high engine RPMs ?
JB
Post A Followup
: Re: Re: Farmall 404 problem
