Re: Farmall 404 problem
Posted by Chet Glenn on July 09, 2003 at 09:52:12 from (66.137.173.92):
In Reply to: Farmall 404 problem posted by J in Pa on July 08, 2003 at 16:56:02:
I have had the same problem on my IH404, even took the shaft out and had a machinist cut off the ends, weld a new piece of steel in between to get it to run true. he even made a new brass pilot bushing for it. It also wore out, but I think thatbrass was the wrong choice. At any rate I am looking at having to split the tractor again to try anew. It can be ran like that, but it sets up a great vibratiion when the clutch isa pushed in above idle and it keeps the tranny turning, making it hard to shift gears.
Post A Followup
: Re: Re: Farmall 404 problem
