10/20 carb.
Posted by stanley j. on July 09, 2003 at 16:41:12 from (205.188.209.140):
on a carb on a 10/20, what is the correct setting on the jets, also which one is the idle and load on the carb, one ajustment is on the top of the carb. and the other on the bottom, also need to know what settings to start out with, thanks for your help. stanley
Post A Followup
: Re: 10/20 carb.
