Re: 10/20 carb.
Posted by Ken Williams on July 10, 2003 at 09:15:26 from (65.166.191.160):
In Reply to: 10/20 carb. posted by stanley j. on July 09, 2003 at 16:41:12:
Stanley, the fuel adjusting screw is on top of the fuel bowl. Open this up 1 and 1/2 turns. The idle adjustment screw is underneath the carburetor. Open this up 2 and 1/2 turns. After the engine is warmed up, screw in the fuel adjusting screw (in the center of the fuel bowl cover) one notch at a time, until the engine begins to slow down. Then, back this screw back out carefully, until the engine regains full speed, then stop. I hope this helps, Ken
Post A Followup
: Re: Re: 10/20 carb.
