Re: FARMALL SUPER A HELP
Posted by Vern on July 09, 2003 at 21:30:18 from (67.75.202.171):
In Reply to: FARMALL SUPER A HELP posted by TOWNSEND on July 09, 2003 at 20:23:49:
If it has hydraulics it is a Super "A" & has to be a '47 or later. Did you drain ALL gasoline from tank & carb & fill with NEW gasoline?
The points will need cleaning. If it has a magneto the point gap is .013". Not sure about distributor point gap. It might help to remove the plugs and squirt some oil into the cylinders to help the compression.
I'm sure there will be more suggestions from others on this board. Good luck
Vern
Post A Followup
: Re: Re: FARMALL SUPER A HELP
