Re: Farmall H sounds like a John Deere B
Posted by lindy on July 10, 2003 at 07:00:23 from (216.189.131.125):
In Reply to: Farmall H sounds like a John Deere B posted by john on July 09, 2003 at 18:52:30:
Put a timing light on it, and eliminate the possibility that something changed with the points adjustment.
Mags have no tolerance for humidity. Spray some dryer of some kind in there.
Check the plugs again. Today's gas fouls them up something fierce.
I don't think the carb is at fault, unless there's black smoke coming out of the stack. Any carb problem on the starving side results in backfiring kind of symptoms.
It's electrical, I'm sure.
Post A Followup
: Re: Re: Farmall H sounds like a John Deere B
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
