Re: Re: Loss of Power while under load- Super A
Posted by PGNS on July 10, 2003 at 08:25:27 from (142.176.86.254):
In Reply to: Re: Loss of Power while under load- Super A posted by CNKS on July 09, 2003 at 19:16:49:
It has a distribter and the new points were set at "02", same with the new plugs. I put in a new sediment bowl last week. I set the float for the carb(Carter) so that the float is level with the base of the carb. It was up on a 30 degree angle so I adjusted it. Did I adjust correctly?Gas tank was cleaned and lines clear. New needle and seat- though it seems to stick at times. Engine runs fine now except under load.
Post A Followup
: Re: Re: Re: Loss of Power while under load- Super A
