Re: Super H Low HP
Posted by Randy in NE on July 11, 2003 at 05:06:42 from (216.58.237.20):
In Reply to: Super H Low HP posted by Eric on July 10, 2003 at 21:44:03:
The timing marks on these old tractors are a bear to find. Most old mechanics will time it by ear. You do about the same thing with the idle mixture screw. Turn it in until it starts to run rough then back it out about 1/2 turn. It may take several attempts to do this since you are adjusting two things at once. The timing should be a "one adjustment" but wouldn't hurt to check it again after adjusting the carburetor. Check to make sure that it runs good a full throttle. You can get a feel for how it is running by riding the brakes a little while starting out in 5th gear. Not scientific but will give you an indication as to what kind of an 'attitude' it has.
Post A Followup
: Re: Re: Super H Low HP
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
